Moving Devices Between Locations: A Step-by-Step Guide
I’ve recently been reorganizing my smart home setup and found myself needing to move several devices from one location to another. After a bit of trial and error, I figured out a smooth way to do this without any hiccups. Here’s how I did it:1. Access the Modeling Section: First, I navigated to the Modeling section of my system. This is where all the device configurations and locations are managed.2. Toggle Edit Mode: I clicked on the toggle to enable edit mode. This allows you to make changes to the device placements.3. Select the Source Location: I chose the location where the devices I wanted to move were currently situated. This brought up a list of all devices in that area.4. Search and Select Devices: Using the search function, I quickly found the devices I needed to move. It’s a time-saver if you have a lot of devices spread out across multiple locations.5. Initiate the Move: Once the devices were selected, I clicked on Move X devices. It’s a straightforward step that initiates the transfer process.6. Choose the Destination: The final step was selecting the new location where I wanted the devices to be. After confirming, the move was completed seamlessly.This process was much simpler than I initially feared. It’s great to see how intuitive the system is, even for tasks that might seem a bit tricky at first glance. I’d love to hear if anyone has other tips or tricks for optimizing their smart home setup!
