Hey everyone, I wanted to share my recent experience with setting up MQTT and camera streaming in Home Assistant. It’s been quite the journey, but I managed to figure it out with some help from the community. Hopefully, this can assist others who might be facing similar issues!
First, I ran into a problem where my MQTT broker wouldn’t start. The error message indicated that port 8884 was already in use. I initially thought it might be due to another Raspberry Pi I had running with Node-RED and MQTT. I turned that machine off, but the issue persisted. After some research, I realized that other add-ons like Node-RED or Visual Studio Code might still be using that port. I eventually found a solution by changing the port configuration in the MQTT add-on settings. It was a bit frustrating at first, but problem-solving always feels rewarding once you crack it!
Next, I tackled the camera streaming issue. I have a HIKVISION camera, and while the stream worked fine in the developer tools, it wouldn’t display in Lovelace. I tried various configurations, including using the picture-elements card, but nothing seemed to work. After some digging, I discovered that using the stream component with the ffmpeg add-on was the key. I adjusted my camera configuration to utilize the stream source properly, and voilà! The camera feed now displays seamlessly in Lovelace. It’s such a relief to finally have everything working as intended.
I also wanted to mention the importance of community support. When I was stuck, I reached out in the forums, and someone suggested checking the add-on logs for conflicts. That small tip led me to the solution. It really underscores how valuable this community is. I encourage anyone facing similar issues to not hesitate to ask for help—there are plenty of knowledgeable folks ready to assist.
In summary, while setting up MQTT and camera streaming had its hurdles, persistence and community support made all the difference. I’m now looking forward to exploring more advanced Home Assistant features and sharing my experiences along the way! Happy automating everyone! ![]()
