I’ve been diving into the world of MQTT and Home Assistant lately, and I must say, it’s been quite an adventure!
I recently flashed a Tasmota-lite firmware on a Geeni Wi-Fi bulb and set up an MQTT Broker on my Raspberry Pi. The goal was to get the bulb to auto-discover in Home Assistant, but it wasn’t as smooth as I hoped.
Initially, everything seemed to be working. The bulb connected to my Wi-Fi, and the MQTT Broker logs showed successful connections. However, when I tried to add the device in Home Assistant, it felt like the broker recognized the connection but didn’t acknowledge it as a real device. Frustrating, to say the least! ![]()
After some research and tweaking, I realized that the issue might be with the auto-discovery settings. I had enabled auto-discovery through the GUI, but perhaps the configuration wasn’t quite right. I revisited the MQTT settings in Home Assistant, double-checked the Tasmota device configuration, and even ran SetOption19 1 again to ensure it was broadcasting correctly.
The breakthrough came when I noticed that the auto-discovery proof I had wasn’t correctly formatted. After correcting the configuration and restarting both the broker and the bulb, the device finally appeared in Home Assistant!
The satisfaction of seeing that bulb show up and being controllable through MQTT was immense.
This experience taught me the importance of meticulous configuration and the value of persistence. If you’re struggling with MQTT auto-discovery, here are a few tips:
- Double-check your MQTT Broker settings and ensure auto-discovery is properly configured.
- Verify that your Tasmota device is correctly set up and broadcasting its information.
- Don’t hesitate to restart both the broker and the device if things aren’t working as expected.
It’s also a great reminder of how helpful the Home Assistant community is. If you’re stuck, don’t hesitate to reach out—someone has likely encountered the same issue and found a solution! ![]()
Happy automating! ![]()
