MQTT Configuration and Device Compatibility Tips
Hello everyone, I’ve been diving into setting up my MQTT server with DNSMASQ and MOSQUITTO, and I wanted to share my journey and some tips that might help others facing similar challenges.
Initially, I struggled with redirecting fixed MQTT server addresses to my internal MOSQUITTO server. After some research, I realized that configuring DNSMASQ was the key. If you’re dealing with similar issues, I recommend checking out the official documentation for DNSMASQ and MOSQUITTO—it’s a bit technical, but once you get the hang of it, it’s very rewarding.
Another challenge I encountered was integrating a Danfoss Ally radiator valve with the OpenHAB Zigbee binding. At first, the device would come online but wouldn’t update its channel values. After some troubleshooting, I discovered that manually installing the device using the install code worked, but there were still issues with state updates. I noticed the antenna icon on the device was off, which led me to believe there might be a connectivity issue. After resetting the device and ensuring it was within range, the problem resolved itself.
For those looking to set up a group of lights with specific automation rules, I’ve found that using the ‘One ON → ON else OFF’ setting works well. However, if one light goes offline, it can cause unexpected behavior. To mitigate this, I’ve started using more robust group configurations and ensuring all devices are on a stable network.
Lastly, I wanted to share a trick for displaying sensor data on a Mini-Graph-Card without relying on complex setups. By using consistent YAML configurations and ensuring all sensors are properly registered, I was able to get the graphs working smoothly. If you’re having issues, double-check your sensor configurations and ensure they’re all publishing data to the same topics.
I hope these tips help someone out there. Happy tinkering! :rocket:
