As someone who has been diving into the world of MQTT and smart home integration, I wanted to share my recent experience and some tips that might help others facing similar challenges.
Earlier this week, I encountered an issue where my MQTT broker was refusing connections despite the configuration files appearing unchanged. The logs indicated a ‘Connection refused’ error, which was perplexing. After some research and trial and error, I discovered that the MQTT broker wasn’t listening on the expected port (1883). Adding a listener directive to the mqtt.cfg file resolved the issue, but it was a reminder of how crucial it is to verify port listeners and configurations.
For those struggling with MQTT connectivity, here are a few steps that might help:
- Check Port Listeners: Use
netstat -an | grep LISTENto confirm if the MQTT broker is listening on the correct port. - Validate Configuration Files: Ensure that all MQTT configurations (e.g.,
mqtt.cfg) are correctly formatted and saved. - Test with mosquitto_sub: Running
mosquitto_sub -h <broker_ip> -v -t '#'can help verify if the broker is responding and publishing messages. - Review Logs: MQTT service logs often provide critical insights into connection issues.
If you’re new to MQTT or facing persistent issues, don’t hesitate to reach out to the community for support. There’s a wealth of knowledge and willingness to help in forums like this!
Happy troubleshooting! ![]()
