MQTT Dimmer Configuration Challenges and Solutions
I’ve been diving into integrating my Wago Industrial PLC with Home Assistant using MQTT, and it’s been quite the learning curve! My goal is to control the brightness of my kitchen lights seamlessly, but I’ve hit a few roadblocks along the way. Let me share my journey and hopefully get some insights from the community.
Initially, I set up my MQTT topics to send and receive brightness values. The PLC sends the current brightness level to HA, and I can send commands back to adjust the brightness. On the surface, it seems straightforward, but the devil is in the details. I tried various configurations, including different value templates and command topics, but the results were inconsistent.
For example, when I moved the brightness slider in HA, the light would sometimes not respond at all, or it would jump to an unexpected value. I even tried simplifying the setup by using binary commands (on/off) instead of continuous brightness adjustments, but that didn’t solve the issue either. It was frustrating to see the potential of MQTT integration not being fully realized.
After some research and trial and error, I discovered that the issue might lie in how the brightness values are being interpreted by both the PLC and HA. I realized that ensuring the value templates accurately reflect the expected format is crucial. For instance, using {{ value | float | round(0) }} instead of string-based values helped bridge the gap between the PLC’s output and HA’s expectations.
Another breakthrough came when I decided to test the setup manually. By sending MQTT messages directly from the command line, I could isolate whether the problem was with HA or the PLC. This approach revealed that the PLC was occasionally sending malformed data, which HA couldn’t process. After tweaking the PLC’s configuration, the communication became much more reliable.
Here’s what I’ve learned so far:
  • Consistency in Data Formats: Ensure that both the sender and receiver agree on the data format (e.g., integers vs. strings).
  • Testing in Isolation: Manually sending MQTT messages helps identify where the breakdown occurs.
  • Documentation and Community Support: The HA community forums and documentation have been invaluable in troubleshooting.
I’m still working on perfecting the setup, but I’m confident that with persistence and the right approach, I’ll achieve the seamless integration I’m aiming for. If anyone has additional tips or similar experiences, I’d love to hear them!
