MQTT Dimmer Integration: Challenges and Solutions
Hey everyone! I’ve been diving into the world of MQTT and openHAB lately, and I wanted to share my journey with integrating a dimmer switch. It’s been a bit of a rollercoaster, but I’m excited to talk through the challenges I faced and how I worked through them.
So, here’s the setup: I’m using an MQTT broker to control a dimmer switch, and I ran into an issue when the dimmer was turned off. The system was throwing an error because it couldn’t find the brightness attribute in the JSON payload when the state was OFF. This made sense because, when the light is off, there’s no brightness value to report. But how do I handle that gracefully in my setup?
I started by looking at the code configuration. I had two channels defined for the dimmer: one for the switch state and another for the brightness. The switch state worked perfectly when the light was on or off, but the brightness channel was causing issues when the light was off. The error message was pretty clear, but I needed a way to handle the absence of the brightness attribute without breaking the integration.
After some research, I realized that the problem was with the transformation pattern I was using. The JSONPATH:$.brightness transformation was expecting a brightness value in every payload, which wasn’t the case when the light was off. To fix this, I adjusted the transformation to account for the possibility of the brightness attribute being absent. I also made sure that the OFF state was properly handled without relying on the brightness value.
Here’s the revised configuration I ended up with:
plaintext
Thing topic dimmer “Dimmers” {
Channels:
Type switch : dimmer1 “Eethoek Raam” [
stateTopic=“openhab/light/dimmer1/state”,
commandTopic=“openhab/light/dimmer1/set_light”,
transformationPattern=“JSONPATH:$.state”,
formatBeforePublish=“{“state”:”%s"}“,
on=“ON”,
off=“OFF”
Type dimmer : dimmer1b “Eethoek Raam” [
transformationPattern=“JSONPATH:$.brightness”,
formatBeforePublish=”{“brightness”:%s}",
min=0,
max=255,
step=25
The key takeaway here was understanding how to handle different states in MQTT integrations. When the light is off, it’s okay for the brightness attribute to be missing because the state is already OFF. By adjusting the transformation and ensuring that the OFF state is properly communicated, I was able to resolve the error and get everything working smoothly.
I’d love to hear from others who have tackled similar MQTT integration challenges. How did you handle different states or missing attributes in your setups? Any tips or tricks would be greatly appreciated!
Cheers,
