Hey everyone, I wanted to share my recent success with integrating an MQTT dimmer switch into my smart home setup! ![]()
After some research and trial and error, I finally got my Tuya dimmer switch working seamlessly with MQTT. Here’s how I did it:
Firmware Flashing: I used Tuya-Cloudcutter to flash the device with openbeken firmware. This was a bit tricky but ultimately successful.
MQTT Configuration: I stumbled upon the MQTT UA Client driver, which was exactly what I needed. It supports dimming and provides feedback when the device is toggled, eliminating any ‘black hole’ issues.
Tips for Others: If you’re looking to set up MQTT for dimming, make sure to:
- Check the device’s MQTT topics and payload formats
- Use a reliable MQTT broker
- Test the integration with a simple switch before moving to dimming
Would love to hear if anyone else has similar setups or any additional tips! ![]()
