Hello everyone, I’ve been diving into the world of MQTT integrations lately, and I must say, it’s been quite a journey!
I recently encountered an issue where my MQTT add-on would start up with the default configuration but shut down almost immediately. The logs indicated an error related to inconsistent server certificates and keys, which was a bit perplexing. After hours of searching and troubleshooting, I realized the problem might stem from legacy files from previous installations. ![]()
I decided to take a proactive approach by thoroughly cleaning up any old configuration files and folders. This process involved manually checking directories and ensuring that all remnants of the deprecated YAML config were removed. It was a bit tedious, but it paid off when the add-on finally started without issues! ![]()
In the meantime, I’ve also been exploring the ZWave integration with my Yale Assure 2 lock. While the lock itself works seamlessly, getting the DoorSense feature to show up in Home Assistant was a bit of a puzzle. After some research and configuration tweaks, I found that rebuilding the routes and recalibrating the door sensor via the Yale app made all the difference. Now, I can monitor the door status effortlessly! ![]()
Another project I’m excited about is setting up my Wyze Cam Pan. I was curious about how to define its ‘home’ position, which is where it returns after scanning. Through some experimentation, I discovered that accessing the camera’s settings menu and adjusting the home position calibration did the trick. It’s such a neat feature for keeping an eye on different areas of my home. ![]()
Reflecting on these experiences, I’ve learned the importance of meticulous configuration and the value of community support. If anyone else is facing similar challenges, especially with MQTT or camera setups, I’d be happy to share more detailed steps or tips! Let’s keep the learning and innovation flowing! ![]()
