MQTT State Customization and Sensor Setup Tips
Hey everyone! I’ve been diving into MQTT and Home Assistant lately, and I wanted to share a couple of things I’ve learned that might help others. First off, I figured out how to customize the status messages for my devices. Initially, I was stuck with the default ‘Unavailable’ message when my lights or switches went offline. After some research, I discovered how to change this to something more intuitive like ‘Offline’ or ‘Not Connected’. It’s such a small tweak, but it makes the interface so much cleaner and easier to understand!
Another project I’ve been working on is setting up a leak detector using an Ecolink Z-Wave Door/Window Sensor. The sensor itself works perfectly, but the state was inverted from what I needed. With a bit of trial and error, I managed to fix this using a sensor template in my sensor.yaml file. Here’s a quick snippet of how I did it:
yaml
binary_sensor.ecolink_doorwindow_sensor_sensor_6_0:
friendly_name: Attic_Leak_Detector
sensor:
  • platform: template
    sensors:
    Attic_Leak_Detector:
    value_template: “{% if is_state(‘binary_sensor.ecolink_doorwindow_sensor_sensor_6_0’, ‘on’) %}Normal{% else %}Alarm{% endif %}”
This little setup now alerts me properly when water is detected, which is a huge relief for peace of mind!
I also wanted to mention something about variable usage in configurations. If you’ve ever found yourself typing the same long device ID over and over, you might appreciate this tip. You can store these IDs in variables to make your code cleaner and easier to maintain. For example:
yaml
variables:
attic_sensor_id: com.animushome.heart.packages.rf433.3bc6421c-5c7f-4911-b4b1-1acf249becfa
sensor:
This not only saves time but also reduces the chance of typos. It’s a small thing, but it makes a difference!
Lastly, I’d love to hear from others who’ve tackled similar projects or have tips to share. Whether it’s MQTT customizations, sensor setups, or just general automation hacks, the more we share, the better we all get!
Happy tinkering everyone! :rocket:
