Multi-Zone Heat Pump Thermostat Control Solution
I recently set up a multi-zone heat pump HVAC system with three Honeywell Vision Pro 8000 Wi-Fi thermostats. Each thermostat controls dampers for different parts of my house. While the system works well, I noticed that the thermostats act independently, which can lead to conflicting settings—like heating in one zone and cooling in another. This inconsistency was a bit frustrating, especially when trying to maintain a uniform temperature across the house.
To address this, I decided to explore SmartThings programming to create a unified control system. As a retired software developer, I wanted to leverage my background to simplify the process. After some research, I discovered that SmartThings could be used to create a virtual switch that changes the heat/cool/off mode on all three thermostats simultaneously. This would eliminate the need to adjust each thermostat individually.
Here’s what I did:
  1. Identify the Thermostats: I started by ensuring all three Honeywell thermostats were properly connected to my SmartThings hub. They communicated seamlessly, which was a great starting point.
  2. Create a Virtual Switch: Using SmartThings, I created a virtual switch labeled “Zone Mode Control.” This switch acts as a central command for all thermostats.
  3. Set Up Routines: I programmed routines that change the mode of all thermostats when the virtual switch is toggled. For example, turning the switch to “Heat” sets all zones to heat mode, while “Cool” does the same for cooling.
  4. Testing: I tested the system thoroughly to ensure there were no conflicts or errors. It worked perfectly, and now I can control all three zones with a single tap.
This solution has been a game-changer for my home comfort. It’s not only more convenient but also ensures energy efficiency by preventing conflicting settings. If anyone has questions or needs help setting up something similar, feel free to reach out!
I’m excited to continue exploring SmartThings and see how else I can optimize my smart home setup. Happy tinkering everyone! :rocket:
