Multiple switches for single lamp installation
Hello,
Does anyone know if the Aqara Dimmer Switch H2 EU supports being installed in multiple places to control a single lamp? I currently have existing ZWave dimmers that I want to replace with Zigbee/Thread dimmers, but currently have several situations where two switches control the same light, and both can dim the lights equally. Is this supported by the Aqara dimmer switches, or any other non dimmer Aqara European switch?
Setting stuff up via Node Red you can essentially do whatever you want. You can even make it contextually aware regarding time of day or room you’re present in. The sky is the limit with that system.
