Multisensor FP 400
Hi everyone
I wonder if anybody can help. I’m having a few issues with the multisensor FP 400 one in my kitchen one in my living room walking into the living room triggers the lights to come on but after watching TV or having a meal in the kitchen the lights go out while we’re in that particular room any ideas on what I’m doing wrong
Many thanks
Chris.
In my Home Assistant setup, I use FP400 presence for lighting too. For this problem, I would first separate a sensor state change from a light-off command. When the lights go out during TV or a meal, does the FP400 show the room as empty, or does it still report presence?
Which app runs the lighting automation, and is the off rule based on absence or a fixed delay after the lights turn on? If presence remains active, I would check that off rule and any other automation controlling the same lights. If presence drops first, knowing whether it happens at the TV seat, the dining position or both would help narrow down the coverage check.
Hi @christopher1 , do you use the Aqara app? Do check the map during this ? If there’s still presence and the light turns off, there’s maybe a problem with the automation
Hi thank you for your help. This is my automation below
Hi, I’m using this condition (Zigbee). A timestamp for turning off the lights isn’t needed; someone might accidentally turn the lights on during the day, and then they’ll stay on indefinitely.
One detail in your screenshots is worth checking before changing the detection settings. The lights-on rule uses the Kitchen FP400, but the lights-off rule shows a Kitchen FP300. Is that really a different sensor, or is it an old device name?
If they are different devices, the FP300 could trigger the lights off while the FP400 still detects you. I would check which physical sensor is selected in each rule and use the intended sensor consistently. That is separate from the absence-duration change gafich10 has illustrated. The screenshots alone do not yet show whether the FP400 itself is losing presence.
