My Broadlink Experience: Switch or Script?
Hey everyone, I wanted to share my recent experience with the Broadlink RM Mini 3. I’ve been exploring how to integrate it into my smart home setup, and I’ve got some thoughts to share!
Initially, I followed a tutorial to set up a switch.yaml file for my remote control. It worked, but I noticed an issue where I had to press the toggle button twice for it to send a signal. After some trial and error, I found a workaround by duplicating the command code. However, this felt a bit cumbersome and not the most efficient solution.
Then, I decided to try using a script instead. I set up a simple script for my TV power control, and it worked seamlessly! Here’s what I did:
yaml
#script.yaml
tv_power:
sequence:
- service: remote.send_command
target:
entity_id: remote.rm_mini3_remote
data:
device: LGTV
command: Power
This approach was much cleaner and more straightforward. It made me wonder—what are the advantages and disadvantages of each method? Should I stick with scripts for all my devices, or are there scenarios where a switch.yaml setup is better?
I’d love to hear your thoughts and experiences. Have you tried both methods? What’s your preferred approach and why? Let’s discuss!
Overall, I’m really impressed with Broadlink’s capabilities. It’s been a great addition to my smart home setup, and I’m excited to explore more possibilities. If you’re considering Broadlink, give it a try—it’s definitely worth the time to set up!
Cheers,
