I’ve been diving into the world of MySensors and Home Assistant, and it’s been quite an adventure! I recently decided to switch from an Ethernet gateway to an MQTT gateway for my MySensors setup, but I ran into a bit of a snag. No matter how I configured it, the sensors just wouldn’t show up in Home Assistant. I could see the MQTT topics being published using an MQTT client, so I knew the sensors were communicating, but Home Assistant wasn’t picking them up. ![]()
After some digging, I realized there might be an issue with how the MQTT topics were configured in my Home Assistant setup. I decided to go back to the basics and carefully review my configuration. Here’s what my current setup looks like:
yaml
mysensors:
gateways:
- device: mqtt
persistence_file: ‘/home/hass/.homeassistant/mysensors.json’
topic_in_prefix: ‘mysensors-in’
topic_out_prefix: ‘mysensors-out’
debug: true
optimistic: false
persistence: true
retain: true
version: 2.0
I started by ensuring that the MQTT broker was correctly configured and that the topics matched exactly what the sensors were publishing. After some trial and error, I finally figured out that the issue was with the topic prefixes. By adjusting them to match the sensors’ topics precisely, everything started working like a charm! ![]()
This experience taught me the importance of meticulous configuration and the value of community support. If anyone else is having trouble with their MySensors MQTT setup, don’t hesitate to reach out—I’d be happy to help! ![]()
