After testing many ‘bolt on’ smart locks, I went with Aqara as I’ve had good experiences with other Aqara products so far. I also really wanted the home key (ios) feature.
Overall, the U200 has worked well, I’ve tied this up with a mini switch T1 but use the manual dial more often now.
Installation, this was simple, the instruction were straight forward to follow. I replaced the cylinder with a suitable one, aligned the u200 housing and chose the correct fitting over the cylinder (comes with multiple fittings), attached the housing with it’s adhesive tape, completed set up and calibration in the app.
Registering users was easy, I’ve registered a pin, fingerprint and also setup home key so I can use my iPhone with it by tapping the keypad.
I’ve set up a wireless mini switch t1 to unlock and lock but mainly use it to unlock since there’s auto lock settings. After a while, I realised I turn the thumb turn more often than the button as I feel it’s quicker this way, there’s a slight delay between switch and it unlocking.
The u200 is consistent and works all the time. The pull back feature really helps and glad it has this feature, especially since I’ve changed the spindle to a split spindle, so the exterior handle is basically a dead handle. There are the odd times where I need to re-calibrate but that’s because my door moves over time making the pullback feature not accurate. The re-calibration takes a few minutes and I would need to do it maybe once every 6 months which is totally fine.
Overall, great product and happy to add it to my collection!
