My experience with the U400 and a few questions about Aqara Home
The U400 is my first and so far only Aqara product. I’ve had it for a while now and overall I’m very happy with it. The UWB unlocking is probably my favorite feature. It has been very reliable and almost always unlocks as I approach the door.
I did struggle with the initial setup. My Apple Home hub is quite far from the door, and I couldn’t get the lock to pair with Apple Home through Matter over Thread while it was installed. I ended up removing the lock, bringing it closer to the hub to complete the pairing, and then installing it again.
Since then, Apple Home has worked well. I can usually see the lock and lock or unlock it remotely without any problems.
I also added the U400 to the Aqara Home app using Bluetooth. That works when I’m near the lock, but the lock shows as disconnected in Aqara Home when I’m away. I don’t currently have an Aqara hub, so I think that may be the missing part of my setup.
I’m considering getting a Hub M100 and placing it closer to the lock. Has anyone used this setup?
A few things I’m still trying to understand:
  1. Would an M100 closer to the lock give Aqara Home a more reliable connection?
  2. Can the U400 stay connected to Apple Home and Aqara Home at the same time?
  3. Is there a recommended order for setting up both systems?
  4. What extra features would the Aqara hub give me if remote locking and unlocking already work through Apple Home?
  5. Did anyone else have to move the lock closer to their Apple Home hub just to complete the original pairing?
I’m still learning how the Aqara and Apple systems work together, so I may be misunderstanding part of it. Other than the confusing setup, the lock itself has been great and the UWB feature works very well.
Welcome to the forum!
The “disconnected when you’re away” part is normal. Aqara’s FAQ says the U400 shows offline without a hub once Bluetooth drops. An M100 fixes that, and it’s on their supported list.
You can run Apple Home and Aqara Home together. Since it’s already in Apple Home, you generate a new pairing code from Apple Home and use it to add the lock to the M100.
Your pairing trouble fits too: the FAQ says keep the lock within about 5 m of the hub while pairing, or 3 m through a wall. Honest note on the hub’s extras: I run a U400 on an Aqara hub, and the Aqara app only gives me about 6 automation triggers for it, so don’t expect a ton beyond remote control and remote passwords.
That was quick! Thank you for your response. I will have to give the M100 a try. Best!
