Hello everyone! I wanted to share my recent experience setting up smart lighting in my home using Hubitat. It’s been quite a journey, and I thought I’d walk you through it in case you’re considering something similar.A few weeks ago, I decided to upgrade my lighting system to something more modern and energy-efficient. I had heard great things about Hubitat, so I decided to give it a try. My main goal was to create a system that could be controlled via my smartphone, allowing me to adjust brightness and colors with ease.At first, I was a bit overwhelmed by the number of options available. There are so many devices and integrations to choose from! But with a little research and some guidance from this forum, I managed to narrow it down to a few key components that would work best for my setup.One of the biggest challenges I faced was setting up a smart lamp with a dimmer. I wanted something that could seamlessly integrate with my existing smart home ecosystem. After some trial and error, I settled on a Tuya smart switch paired with an E14 LED bulb. The setup wasn’t too complicated, but it did require a bit of tweaking to get everything working smoothly.Here’s a quick rundown of what I did:1. Choosing the Right Devices: I opted for a Tuya smart switch because of its compatibility with Hubitat and its ability to handle both on/off and dimming functions. The E14 LED bulb was perfect for my needs as it supports both color and brightness adjustments.2. Installation: The installation process was straightforward. I simply replaced my existing switch with the Tuya smart switch and connected the bulb. The real magic happened when I paired everything with Hubitat.3. Integration with Hubitat: Once everything was physically installed, I used Hubitat’s automation editor to create a simple routine. This allows me to control the lamp with a single tap on my phone. I even set up a scene where the light dims gradually in the evening, creating a cozy atmosphere.4. Testing and Fine-Tuning: After setting everything up, I spent some time testing different scenarios. I wanted to make sure that the lamp responded correctly to voice commands and that the dimming function worked smoothly. It took a bit of tweaking, but everything now works like a charm.One thing I learned during this process is the importance of starting small. It’s tempting to try and automate everything at once, but taking it step by step makes the process much less overwhelming. I also realized how valuable community forums like this one can be. The tips and advice I found here were invaluable in helping me overcome some initial hurdles.If you’re considering a similar project, my advice is to do your research, start with a small setup, and don’t hesitate to reach out to the community for help. The satisfaction of seeing your home come to life with smart technology is well worth the effort!I’d love to hear about your experiences with smart lighting or any tips you might have for someone just starting out. Let’s continue to learn and grow together in the world of smart home automation!
