Hey everyone, I wanted to share my recent experience setting up Z-Wave devices in my smart home. It’s been quite a journey, but I’m happy to say I’ve figured it out!
I recently purchased a Z-Wave Plus Plug-In Power Monitor from Monoprice, and I was excited to integrate it into my system. However, when I tried adding it to the database, I couldn’t find the ‘Add’ button. After some research, I discovered that I needed to be approved as a contributor. Once that was sorted out, I was able to upload the XML file and get the device up and running.
But the real challenge came when I tried to connect my Echo Dot to my Roland keyboard using an aux audio cable. I kept getting an error message saying that the aux audio option wasn’t available. After some troubleshooting and reaching out to the community, I realized that the Echo Dot doesn’t support aux input for music streaming. Instead, I switched to using Bluetooth, which worked perfectly.
Another issue I faced was with my Z-Wave Aeon Stick. After a system update, the controller went offline, and I was getting a ‘Serial Error: Port /dev/ttyUSB0 does not exist’ message. I tried everything from restarting the system to unplugging and replugging the device, but nothing worked. Finally, I found a solution by adjusting the permissions for the ttyUSB0 port in the PaperUI configuration. It was a bit technical, but it saved the day!
Through these experiences, I’ve learned the importance of patience and thorough research when setting up smart home devices. The community here has been invaluable, and I’m grateful for all the helpful advice I’ve received. If anyone else is struggling with similar issues, don’t hesitate to ask—there’s always someone willing to help!
Happy tinkering everyone! ![]()
