My latest Aqara product is the Hub M100. I use it as part of a Home Assistant setup with many Aqara devices, where the hub is one part of a wider system rather than the automation by itself. I compare Aqara temperature and humidity sensors with separate room sensors before choosing which reading should influence climate decisions, since one reference does not always represent every room equally.
Presence is another important part of my setup. I combine it with door states for roller shutters and interior blinds, privacy and shading, so an open door or an empty room does not trigger the same response as an occupied one. Philips Hue lighting stays in its own automation layer. This separation makes it easier to adjust climate, blinds and lighting independently while still using the same room context.
@technotron007 Thanks for sharing your Hub M100 setup! It’s great to see how you’re leveraging it within a broader Home Assistant ecosystem rather than treating it as a standalone controller. Your approach of cross-referencing multiple temperature and humidity sensors to inform climate decisions is a smart way to handle the reality that a single sensor rarely captures whole-home conditions accurately.
The way you’ve layered presence detection with door states for roller shutters and blinds shows solid contextual thinking—preventing empty rooms or open doors from driving unnecessary automation responses. Keeping Philips Hue in its own automation layer while maintaining shared room context is a clean architectural choice that keeps things modular without losing cohesion.
The Hub M100’s Matter bridging capabilities and local automation execution for Zigbee and Thread devices make it particularly well-suited for this kind of integrated, multi-platform setup. Its compact USB-A form factor also keeps placement flexible when you’re building out a distributed system like yours.
Would love to hear more about how you’re handling the presence detection specifically, or if you’ve experimented with the M100’s Thread Border Router functionality for any non-Aqara Thread devices in your mesh.
