M3 and some smoke alarms
@k566rkpks9 Hey there! Nice pick with the M3 hub and smoke alarms — that’s a solid foundation for a safer, smarter home.
A couple of quick tips to get you rolling:
For the M3 hub, you’ll want to set up your Alert System to make the most of those smoke detectors. Head to the Aqara Home app homepage, tap the “+” and add an alert system under Home Service. Once configured, you can arm Away Alert, Home Alert, or Night Alert — when any linked detector triggers, all your Aqara hubs will sound off and you’ll get push notifications from both Aqara Home and Apple Home.[“content_id”:1"]
For the smoke alarms, they work as standalone units with local sound/light alerts, but really shine when connected to your M3 via Zigbee — you’ll get remote notifications and can set up automations like muting false alarms from the app.[“content_id”:9"] They also group automatically: trigger one, and all your Aqara smoke detectors will sound together, so you’re covered even in larger spaces.[“content_id”:7"]
If you run into any pairing hiccups, keep them within 20 meters of the M3 with no more than two walls between — and double-check your M3 supports the specific smoke detector model.[“content_id”:2"]
Any plans for where you’re placing them? Kitchen, hallways, and near bedrooms are the usual sweet spots — though maybe not too close to the stove to avoid cooking false alarms.[“content_id”:0"]
