I’ve been using HomeAssistant for several years and have always been intrigued by DIY projects. Recently, I decided to take the plunge and try out ESPHome for a project I’ve been wanting to tackle: controlling my roman shades. This experience has been both challenging and rewarding, and I’d like to share my journey with you.### The Project: Roman Shades ControllerI wanted to create a system that would allow me to control my roman shades using a Wemos D1 Mini. The goal was to have a reliable, wireless setup that could be integrated into my existing HomeAssistant ecosystem. The motor for the shades has mechanical stops, so power doesn’t need to be interrupted when opening or closing. To control the motor, I used two relays: one to turn the power on/off and another to determine the direction (up or down).### The Setup1. Hardware: I used a Wemos D1 Mini for the main controller. The relays were connected to pins D3 and D2. For user input, I set up another ESPHome device with two push buttons—one for up and one for down.2. Software: ESPHome was the perfect choice for this project. It allowed me to easily configure the relays and buttons, and integrate everything into HomeAssistant without any hassle.### The Challenges- Relay Configuration: Initially, I struggled with getting the relays to work correctly. I had to ensure that the relays were switching at the right moments and that the motor was receiving the correct signals.- Integration with HomeAssistant: While ESPHome made integration straightforward, I had to spend some time setting up the automation rules to ensure smooth operation.### The SolutionAfter some trial and error, I figured out the right configuration for the relays. I also set up the push buttons to send commands to the Wemos D1 Mini, which then controlled the relays. The integration with HomeAssistant was seamless once I had the ESPHome setup correct.### The ResultsThe system works beautifully! I can now control my roman shades both from the push buttons and through HomeAssistant. The ability to stop the shades mid-operation by pressing the button again is a huge plus. It’s satisfying to see a project come together and work exactly as intended.### Tips for Others- Plan Ahead: Take the time to map out your hardware connections and software configuration before diving in.- Test Incrementally: Test each component individually before integrating them. This helps identify issues early on.- Leverage Community Resources: The ESPHome and HomeAssistant communities are fantastic resources. Don’t hesitate to ask for help or share your experiences.### ConclusionThis project has been a fantastic learning experience. It’s shown me the power of ESPHome and how it can be used to create custom solutions that integrate seamlessly with HomeAssistant. I’m already brainstorming my next project—maybe something with smart lighting or climate control. The possibilities are endless!If anyone has questions about this project or wants advice on similar endeavors, feel free to reach out. I’d be happy to help!
