My Successful Integration of Shelly Dimmer 2 for Dual Lighting Control
I recently embarked on a project to integrate a Shelly Dimmer 2 into my home automation setup, and I wanted to share my experience and some tips for anyone looking to do something similar. My goal was to control two separate lighting zones in my living room using a single dimmer, which I thought would streamline my setup and make things more user-friendly.
Initially, I faced some challenges with wiring, as I had to connect the dimmer to two different light circuits. I was worried about damaging the device or causing any electrical issues, but after some research and careful planning, I managed to get everything set up properly. Here’s how I did it:
  1. Wiring Setup: I used the Shelly Dimmer 2’s multi-wire capability to connect both sets of lights. This required some additional wiring, but the Shelly app made it easy to configure the settings once everything was connected.
  2. Configuration: Through the Shelly app, I set up the dimmer to control both light circuits independently. This allowed me to adjust the brightness of each zone separately, which is perfect for creating different ambiance settings.
  3. Integration with Home Automation: I integrated the dimmer with my existing smart home system, enabling voice control and scene automation. Now, I can dim or brighten either zone with a simple voice command or set up schedules to adjust the lighting throughout the day.
  4. Tips for Others: If you’re planning to do something similar, I recommend:
  • Double-checking your wiring to ensure everything is secure and up to code.
  • Taking your time with the app configuration to make sure each zone is set up correctly.
  • Experimenting with different automation scenarios to find what works best for your lifestyle.
Overall, this project has been a great success, and I’m thrilled with how it’s enhanced my home automation setup. If anyone has questions or wants more details, feel free to reach out!
Here’s a quick overview of my wiring setup for reference:
plaintext
  • Zone 1: Living Room Lights
  • Zone 2: Accent Lighting
  • Shelly Dimmer 2 Configuration: Multi-wire setup with independent control
Happy automating!
