Hey everyone! I wanted to share my recent experience setting up InfluxDB on my Hass.io system. As someone relatively new to this, the process was a bit of a challenge, but I managed to get it working smoothly. Here’s how I did it!Initially, I was a bit overwhelmed by the setup, but breaking it down step by step made it manageable. I started by adding the Hass.io Add-on repository to my system, which made it easier to find and install the InfluxDB add-on. Once installed, I followed the component documentation, which mentioned the need for a database named ‘home_assistant’. To create this database, I accessed the InfluxDB GUI by appending port 8888 to my HA’s IP address. From there, I navigated to the Data Explorer and used the ‘Create Database’ option to set up ‘home_assistant’. I also had to create an admin username and password, which were crucial for configuring the add-on properly.After setting up the database and credentials, I updated my configuration.yaml file with the necessary details. To my delight, everything started working as expected! My data began flowing into InfluxDB, and I could visualize it using Grafana. It was a great feeling to see all my home automation data neatly organized and accessible.I wanted to share this experience in case anyone else is struggling with the setup. Remember, perseverance and patience are key, even when things seem tricky at first. If you run into issues, don’t hesitate to reach out to the community for help—we’re all here to learn and support each other!Happy automating! ![]()
