Nest Protect is discontinued. Aqara, please build a mains-wired UK replacement
Our 2019 UK new-build has 3 Nest Protects on the existing mains wiring, and they’re the best alarms I’ve used:
  • Mains powered. They use the new-build wiring, so there are no batteries to chase around the ceiling.
  • App hush. Burnt toast gets silenced from the phone, not with a tea towel.
  • Pathlight. A motion night light comes on when you walk past at night. This is the feature I’d miss most.
Google has stopped selling the Protect, and their official replacement, the First Alert SC5, is only sold in the US and Canada. Typical: the rest of the world gets forgotten, and UK owners are left with no upgrade path.
I run everything else through Aqara and Home Assistant, so Aqara is the obvious move. But the current Smoke Detector is very basic next to the Protect: battery-only, smoke-only, and no night light. Fine for a retrofit, but not a like-for-like swap for a wired new-build.
What I’d buy on day one:
  • Mains-wired (UK 230V, interlinked) with battery backup
  • Matter/Thread with local control
  • App hush and self-test reports
  • Motion night light
  • Smoke, heat (kitchen) and CO versions
  • BS EN 14604 certified for UK new-build regs
Would anyone else in the UK switch? Happy to beta test and write it up.
Im not in UK but in Denmark, and I would gladly test that as well. Don’t necessarily need the night light but I’ll survive if it’s there (recommend the opportunity to turn it off if you build it in).
Logo at the Siemens etc and go for the same power connection and mounting bracket if you want to make it easy for everyone to replace the current 220-240V smoke and fire detectors :+1:t2:
Thanks @mikkelgraverjensen, great shout on matching the existing mains connector and bracket, that would make swapping them in really easy. Funny thing about the night light: it was an unexpected feature on my Nest Protects. I didn’t buy them for it, but I can’t live without it now! Making it optional so it can be turned off makes sense too.
