Hello everyone! I hope you’re all having a great day. I wanted to share my recent experience installing a Nest thermostat, as I encountered a common issue that might be helpful for others to hear about.
Like many of you, I’m a tenant and couldn’t modify the existing wiring in the furnace. The old thermostat had a jumper between Rc and Rh, but no C wire. Without access to the furnace, I decided to use an external 24V transformer to power the Nest.
Here’s where I hit a snag: I wasn’t sure whether to connect the R wire from the furnace to the Nest or just use the R wire from the external transformer. I didn’t want to risk damaging anything, so I did some research and reached out to the community for advice.
After some helpful tips from others, I realized that using the external transformer meant I should only connect the R wire from the transformer to the Nest. This setup worked perfectly, and I was able to install the Nest without any issues.
I wanted to share this because it’s a common problem for those who can’t access their furnace wiring. It’s all about understanding how the external transformer integrates with the existing system. I’m really happy with how it turned out and the convenience the Nest thermostat brings to my home.
If anyone else is in a similar situation, I hope this helps! Thanks to everyone who contributed their knowledge and experience. It’s amazing how a community like this can make such a difference.
Best regards,
