NETATMO Outdoor Weather Station Battery Solution and Mounting Tips
After 15 months of use, my NETATMO outdoor weather station began showing signs of failure, despite regular battery replacements. The device would often fail to transmit data, resulting in incorrect readings. Frustrated and unable to find a solution through official channels, I decided to take matters into my own hands.
Upon closer inspection, I noticed debris in the battery compartments. Using a pencil eraser, I cleaned the contacts and installed fresh Duracell AAA batteries. To my delight, the device blinked green and reconnected to the indoor station, functioning perfectly for over 24 hours. This experience taught me the importance of maintaining clean battery contacts and using high-quality batteries.
For those looking to mount their outdoor units, I recommend placing them in a ventilated container to protect against weather elements while allowing proper airflow. Avoid sealing the device in plastic bags, as this can trap moisture and cause issues. Additionally, consider using lithium batteries for outdoor use, though be cautious in warm climates.
I hope this solution helps others experiencing similar issues with their NETATMO devices. Happy tinkering!
