I’ve recently moved into a new property and have gone all-in on the Aqara ecosystem. I’ve just installed a range of devices including Presence Sensors (FP2, just before they released FP400!!!), M3 Hubs, doorbell cameras, and various other sensors and smart home devices.
As a complete newcomer to Aqara, I’m now at the stage where I need to start building automations, and I’m looking for the easiest and most effective way to do this.
A few questions for those with more experience:
What is the best way to design and manage Aqara automations without spending weeks learning the system?
Are there any tools that help visualise or create automation logic more easily than using the Aqara app alone?
Is it possible, or worthwhile, to integrate the Aqara platform with AI tools such as Microsoft Copilot or ChatGPT to help create automation rules and routines?
Has anyone used AI to develop automation logic and, if so, how effective was it in practice?
Would I be better off investing time in platforms such as Home Assistant, Node-RED, Apple HomeKit, Google Home, or another ecosystem to manage everything centrally?
Are there any common mistakes that new Aqara users tend to make when setting up automations that I should avoid?
My main objective is to create reliable, intelligent automations while keeping the setup and ongoing management as simple as possible. I’m particularly interested in hearing from users who have deployed Presence Sensors and the M3 Hub extensively.
Any advice, recommended software, examples of useful automations, or lessons learned would be greatly appreciated.
I was in a very similar position, although I originally built all of my automations within the Aqara app. I’ve since moved pretty much all of them over to Home Assistant and used AI quite a lot to help me build the automations. The biggest catalyst for moving was the fact that you can’t back up the hubs, so if, like me, you accidentally wipe one late at night, there’s no recovery!
For me HA has been much better once the automations started getting more complicated, especially when you want devices from different ecosystems working together. AI has also made the learning curve much easier as I can basically explain what I want the automation to do and work through the logic from there.
I still use the Aqara app for setting up/managing the Aqara devices, but HA is now where I do the automation side.
One thing I would suggest is starting with a couple of simple automations first rather than trying to build everything at once. Once you’ve got those working reliably it’s surprisingly easy to build on them.
Thanks for that. I do intend to nearly crawl before anything else.
Was wondering about Home Assistant, but doesn’t that mean I’d have yet another piece of equipment to learn, manage and keep runnig?
@SteveG on “yet another box to manage”: yes, it is one more thing, but it’s the last one. I run a pair of FP2s plus a lot of other gear through Home Assistant, and in practice it’s been the opposite of more work:
Buy the appliance, not the project. A Home Assistant Green (or Yellow) is a plug-in box with nothing to build. Updates are a button in the UI. The “keep it running” part is mostly just clicking update once a month.
It fixes the backup problem hector hit. HA takes full backups of all your automations (to a USB stick, a NAS, or offsite with Nabu Casa). If something gets wiped, you restore instead of rebuilding from memory.
Keep Aqara doing what it’s good at. Pair and configure devices in the Aqara app (FP2 zones especially), then bring them into HA over HomeKit or Matter and build the automations there.
On AI: I use it for nearly all of my automations and it works well, with one rule: check the entity names it writes. AI will confidently invent a sensor name that looks right but doesn’t exist, and depending on where that name sits, the automation either errors out or quietly never fires. Paste in your real entity IDs and have it work from those.
And one FP2 lesson since you mentioned presence: an FP2 tells you someone is in a zone, not who. If an automation should only fire for a specific person (a personal morning announcement, say), you’ll need something that identifies people, like a phone or BLE tag, alongside it. I learned that when a briefing meant for one person fired for someone else.
