Hi,
The new firmware installed yesterday. Since then I’ve had a couple of occasions where the stat kept cooling when sensors around the home were showing much cooler temperatures. Adjusting the temp higher on the stat didn’t stop the cooling. The only way I found to stop the cooling was to adjust the data source a couple of times.
The stat is in the hallway. The temp reported was 79 (cool to 78). Sensors around the home were showing 76 or below.
All very odd.
The stat is connected to Apple Home and HomeKit is controlling the stat.
I adjusted the stat to pull it’s temperature from the stat itself. If the same problem happens again I plan to turn off adaptive temperature in the HomeKit. If the problem keeps occurring, I will disconnect the stat from HomeKit.
Anyone else seeing this or similar behavior?
Thanks,
John
