New HomeKit energy future - Aqara support
Hello, I just found that with iOS 27 Apple released energy measurement to supported devices. One of my TP Link smart plug shows energy, but other devices from Aqara (smart plug, relay etc.) that support this in app does not show it in HomeKit. Does Aqara plan to add this future to those devices or should I switch to other brand? Thanks for info
Quite interestingly, my Apple Home shows power usage for Aqara Smart Plug EU (the older one).
I just have to open the room view to see it. However, the energy usage has mysterious “T” unit (and tapping it opens an empty window).
Btw I use Hub M3 and use Matter integration (instead of HomeKit integration) to connect it with HomeKit
It does not work for me, neither.
I guess you need the M3 hub to make it visible in Apple Home? My Aqara smart plugs are connected to an E1 bridge but they don’t show energy usage
The E1 hub does not support Matter integration, I guess it only works via Matter (so you need an M3 or other Matter-enabled hub).
I have two different smart plugs - one is TP Link Tapo (Matter connected)
And second Aqara EU plug connected via Aqara Hub to HomeKit.
And you can see, it works with TP Link, but not with Aqara. Is the problem that I connect it via bridge?
Oh and for info I have M3 HUB
