NHS worker needing 6 hands to unlock the front door, looking for a better, smarter way!
Hello! I’m really hoping (I’m within the UK) and excited to hopefully request early access to the Smart Lock U600 … we’re a smart home family but unfortunately when we moved into this home have uPVC doors on the front, making it difficult for us to find a smart lock for our home. However I’ve seen the U600 & it’s got us all excited! I’m a community nurse & parent - I’m almost always having to play juggle when it comes to opening the front door and I’m desperate for this what seems like small step of my every day life just become THAT bit easier! Annoyingly I don’t think the other locks by aqara will work because they require our door to have the system where you can still unlock the door if a key is in the lock from the inside… ours does not. Please help me rack up some points but also some advice potentially on these smart locks?! Thankyou champs!
@charlie_pearce1 Hey there! Totally feel you on the juggling act — between NHS shifts and parenting, you deserve a door that actually helps, not adds to the chaos.
So here’s the thing with the U200 (Aqara’s current retrofit lock for the EU/UK market): it specifically needs a cylinder with an emergency feature that lets you unlock from the outside even when a key’s inserted inside. Since your uPVC door doesn’t have that, you’re right — the U200 likely won’t work for your setup.
The U600 you’re eyeing sounds like it could be the answer for tricky uPVC doors, though I don’t have any details on it in my reference materials yet. Fingers crossed it launches soon for the UK!
In the meantime, for early access requests and to get proper guidance on compatibility with your specific door setup, I’d definitely recommend reaching out directly to Aqara’s team. They can look at your cylinder type and give you a definitive yes/no before you get too far down the rabbit hole.
Contact the Aqara Home App Customer Service Team (Profile > Help & Feedback > Customer Service) or scan the QR code:
This will be more efficient. If you do not have an Aqara Home account, please click here to create a ticket.
Rooting for you to get that hands-free door situation sorted — you’ve got enough on your plate without wrestling keys at the doorstep
Hey @charlie_pearce1 , maybe you can provide us some pics/ videos of your current door / lock situation- so we can better understand
You could look at changing the cylinder in your door to one that is compatible with the Aqara U200? It’s honestly a 5 minute job to replace it, only a couple of screws and the old cylinder slides out. The trickiest past is making sure you get a new cylinder of the right length. If you temporarily remove the old one, you can measure it easy enough then pop to a hardware store or Amazon and pickup a new one. I did this when I moved into my new house - picked up a more secure lock that also had the thumbscrew on the inside and it’s worked with the U200 just fine.
Aqara also sell a cylinder specially for the U200 which can be adjusted to match the size of your existing one. Just be aware that the Aqara cylinder uses it’s own unique keys.
