Non-Neutral Wire Installation Solution: Simple and Cost-Effective
Hey everyone, I wanted to share a fantastic solution I recently discovered for integrating non-neutral wired installations into smart home systems. This method not only saves money but also allows seamless integration with platforms like Home Assistant or Google Home. Let me walk you through how it works and why it’s been a game-changer for me!
The Problem
If you’ve ever dealt with older lighting setups, you know the frustration of non-neutral wires. These setups often lack a neutral wire, making it impossible to install smart switches directly. Replacing or rewiring these systems can be expensive and time-consuming, especially if you’re not an electrician.
The Solution
I stumbled upon a brilliant hack through a video by “My Project Box” that uses a Sonoff Basic R5 Switch (Matter over Wi-Fi). This solution is incredibly affordable, costing under $10 per device, and requires minimal setup. Here’s how it works:
  1. Hardware Setup: You use the existing switch to power the Sonoff Basic R5. By shorting both outlets of the physical switch, the switched wire remains on except for a brief moment when the switch is toggled.
  2. Sonoff Integration: The Sonoff switch is placed in front of the lamp. It receives power from the neutral and the now-always-on switched wire. The switch toggles the lamp when it detects the short break caused by the physical switch.
  3. Internal Capacitors: These ensure the Sonoff doesn’t lose power during the brief moment the switch is thrown, maintaining seamless operation.
Why It Works
This setup is brilliant because it doesn’t require any rewiring or additional neutral wires. The Sonoff switch acts as a smart intermediary, allowing you to control the lamp through your smart home system. Plus, it supports multiple physical switches in a circuit, making it versatile for different setups.
My Experience
I’ve implemented this solution in my home, and it’s been a lifesaver. It’s allowed me to upgrade several old lighting circuits without the hassle and cost of rewiring. The best part is that it works seamlessly with my existing smart home setup, providing state information and allowing me to toggle lights through voice commands or the app.
Tips for Success
  • Test Thoroughly: Before finalizing, test the setup to ensure the Sonoff switch detects the switch toggles correctly.
  • Use Quality Components: While the Sonoff Basic R5 is affordable, invest in good quality switches to ensure reliability.
  • Plan for Multiple Switches: If you have multiple switches controlling the same circuit, this setup can handle it without any issues.
Conclusion
This solution has been a revelation for me, transforming outdated lighting systems into fully integrated smart home components. It’s a testament to how creativity and the right tools can solve even the most frustrating problems. If you’re dealing with non-neutral wires, I highly recommend giving this a try!
Let me know if you’ve tried similar hacks or have questions about this setup. Happy tinkering! :rocket:
