Not able to use light lux value as condition for door sensor
Hello, what I’d really like to be able to do is:
add a light lux reading condition from a P1 Sensor when a door sensor detects an opening.
The P1 sensor can take as a condition it light sensor reading when actions come from it’s movement drtection, but when the automation is triggered by the door sensor this option is not available. Using Zygbee and G3 hub… I presume that it’s just not a P1 sensor function but I’d like to make sure. Thanks in advance for your help.
Cheers
Hello, yes, this function is not available, the measurement of the luminous flux begins only after movement in the room.
Hello @skiwithandre
This sensor does not support this, if you need to use a light sensor without motion detection, you can choose aqara P2 for these tasks - it can transmit lighting data regardless of movement.
:omzdu6fxikcn5wgqqcyj9q_62:
