Offset data at temperature and humity sensor
Hello, can you please add the chance to put on a “Off set value” to all sensors which are related to temperature and humidity.
Because sometimes the sensor is at differnet hights located, so it will be helpful to “adjust” the real data a little bit. The adjustment of the offset data should be in the steps +/- 0.1 Degree / % of Humidity.
Thank you and with kind regards
@signom2000 Hello! Thank you for sharing your suggestion about adding an offset feature to the Temperature and Humidity Sensors. I understand how having the ability to adjust data readings based on sensor placement, such as different heights, could be beneficial for achieving more accurate measurements.
Currently, the Aqara Temperature and Humidity Sensor automatically reports data based on certain variations but does not support manual offset adjustments. Your feedback is valuable, and it would be great to see this feature included in future updates. I encourage you to share this suggestion directly with our Customer Service Team for further consideration. You can reach them through the Aqara Home App by going to Profile > Help & Feedback > Customer Service, or by scanning the QR code provided:
Customer Service QR Code. If you don’t have an Aqara Home account, please click here to create a ticket.
Thank you again for your input, and I hope this feature can be considered in future enhancements. Feel free to share any more ideas or questions you might have!
Hi signom2000,thank you very much for your suggestion.We will discuss and evaluate this feature internally.
