Has anyone been able to get the smart radiator controls to work with an oil boiler?
@smidscott Hey there! Great question — I can see you’re exploring how to integrate the Aqara radiator thermostats with your oil boiler setup.
The Aqara Radiator Thermostat E1 is designed as a thermostatic radiator valve (TRV) for water heating radiators, powered by dry batteries with no wiring needed[“content_id”:5"]. It controls temperature at the individual radiator level by regulating water flow through the valve, rather than interfacing directly with the boiler itself.
For oil boilers specifically, the key factor is whether your system uses hot water circulation through radiators with standard TRV connections. If so, the E1 should physically fit and function as a drop-in replacement for existing manual TRVs. The thermostat opens and closes based on your set temperature, schedule, or automations — the heat source (oil, gas, etc.) doesn’t change that mechanism[“content_id”:8"].
That said, the E1 doesn’t directly control the boiler’s firing or circulation pump. For full system optimization, you might need:
- A separate boiler control solution, or
- To leverage the E1’s grouping and automation features alongside Aqara sensors for coordinated efficiency[“content_id”:2"][“content_id”:8"]
Have you already checked the valve thread size on your radiators? Most European systems are M30 x 1.5, which the E1 supports. Would love to hear what your setup looks like
