One of three U400 slow to respond to UWB
Had two U400s for a few months, UWB works perfectly. Just installed a 3rd one (finally available from Apple Store, all of them are the deluxe version). However, for this new U400, when I walk up to the lock, the green UWB LED never lights up right away. I have to stand in front of the lock for 1-2 seconds (~1 foot in front) before the LED comes on and the door will then unlock. And ~30% of the time, the LED just never comes on and door will not unlock.
For my other 2 U400s, the green LED will always light up a few feet before I even reach the door (as I am approaching). The difference in reaction time (and sensitivity?) is VERY obvious.
The U400s are all on the same Thread network (and according to the Eve app, they all have green/excellent signals). All are on the latest 3110 firmware, all using default settings. Feels like I got a lemon for the 3rd one? I will be happy to collect logs and do more experiments. I have tried with different Apple Watches, iPhones etc and makes no difference. The new U400 is constantly slow to (or no) respond.
Please kindly advise. I am 3 weeks past the purchase date, so can no longer return to Apple Store :frowning:
I would look at things that could be causing signal interference in that specific area.
If possible just for testing can you move your Thread antenna device closer to see if it improves the lag/reaction time? Thread can be finicky at times.
Are they all running same FW version?
I’m sure you’ve done it, but make sure you have the latest firmware. Mine had the issue for a brief time then a new update fixed it. Outside of that, maybe phone and/or watch UWB signal strength is being hindered by something? Just thinking of possible causes…
Thanks for all the suggestions!
  • The 3 locks are all running on v3110
  • Unfortunately I cannot move the thread router (Apple TV 4k 3rd gen + Ethernet)
  • There is an extra hop (with an Eve smart plug) to the router, but so did the other 2 locks (routed through a different Eve smart plug).
  • And it is literally wide open where I walk up to the lock, no furniture/wall etc
:frowning:
On your iPhone/iPad or Desktop Home App open the Home App navigate to the top right three dots …
Home Settings-Home Hubs and Bridges. Turn off Automatic Selection and be sure to select your hard wired Apple TV 4K as the preferred Home Hub.
See if this helps improve your Thread network latency. Auto select is not your friend.
I am already on fixed hub selection (Apple TV 4K is always the hub).
Thanks a lot for your support!
We’re thinking the problem might be a loose UWB antenna connection. Would you mind sharing your lock’s firmware version and some photos of how it’s fitted into the door cutout?
If this turns out to be a manufacturing fault, I’ll reach out to our after-sales team right away to sort this out for you (Support@aqara.com).
Hey there! I just received my lock yesterday and installed it today. Very similar setup (but I only have 1, but it is the Apple one).
Apple TV 4K (latest gen), wired ethernet, not auto selected as the hub.
I have to step right up to the door and wait there for 1-2 seconds before the green light goes on.
This is a beautiful lock, but I replaced my Schlage Encode Plus tap to unlock that’s been flawless for 3-4 years. I really want this to work, but I only have a 2-week return window with Apple and won’t hesitate to return it (UWB is the headline feature!). It’s gotta work.
I have also gone into the advanced settings and change the distance to 1,5m, 2m, even more (and yes turned off/on the Unlock on approach in Wallet on both my iPhone 17 Pro Max and Apple Watch Ultra).
Felt I would respond here instead of creating a new thread since there doesn’t appear to be a firm resolution here and the OP hasn’t responded.
Sorry meant to say I went up to 1,6m for the distance.
So from what I gather from this thread is the Deluxe models from the Apple Store specifically are slow to respond to UWB but the standard versions (say - from Amazon) are much faster with UWB? Is that a fair assesment?
