OpenHAB 4.0.4 Daily Crashes: Possible Solutions and Troubleshooting
After updating to OpenHAB 4.0.4, I’ve encountered daily crashes, primarily due to health check timeouts. Here’s a structured approach to diagnose and resolve the issue:
1. Network Configuration Check
  • DNS Issues: The logs indicate DNS query timeouts to 192.168.178.37. Ensure your DNS settings are correct and the network is stable. Consider switching to a reliable public DNS like Google’s 8.8.8.8.
  • Firewall/Antivirus: Temporarily disable any firewall or antivirus software to rule out network interference.
2. Docker and Resource Allocation
  • Resource Limits: Verify Docker’s resource allocation. Ensure the container has sufficient CPU and memory. Adjust settings in /etc/docker/daemon.json if necessary.
  • Container Health Checks: Review and adjust health check configurations in your Docker setup. Increase the grace period or disable strict checks temporarily.
3. OpenHAB Version and Logs
  • Bug Check: Research OpenHAB forums or GitHub for known issues with version 4.0.4. Consider downgrading to a stable version if bugs persist.
  • Log Analysis: Use tools like journalctl -u openhab to monitor system logs for patterns or spikes in resource usage.
4. Docker Installation and System Health
  • Docker Reinstallation: Backup data, reinstall Docker, and restore the setup to eliminate corrupted installations.
  • System Monitoring: Use tools like htop or glances to monitor CPU, memory, and disk usage in real-time.
5. cgroup and Container Management
  • cgroup Settings: Adjust cgroup configurations to prevent resource management issues. Updating Docker might also resolve these warnings.
By systematically addressing each area, you can identify the root cause and implement effective fixes to stabilize your OpenHAB setup.
