OpenHAB Modbus Integration and TXP Power Settings
Hi all! I’m reaching out to share my experience and see if anyone else has tackled similar challenges. I’ve been diving into integrating Modbus devices with openHAB, specifically using the Modbus binding to control temperature setpoints. It’s been an interesting journey, and I’d love to hear how others have approached this or similar problems.
First, let me walk through my setup. I’m using openHAB 2.2.0 with a Modbus TCP connection to a slave device. The configuration looks solid on paper, but I encountered an issue where decimal changes in the setpoint weren’t being written to the Modbus slave. After some research, I realized that openHAB might be defaulting to writing WORDS instead of float32 values. This was a bit frustrating, but it also became a learning opportunity!
I decided to dig deeper into the Modbus binding documentation and found some helpful tips on forcing float32 writes. It turns out adjusting the configuration to explicitly set the value type to float32 made a world of difference. Now, both integer and decimal changes are updating as expected. It’s a small tweak, but it makes a big impact on the system’s responsiveness.
I’m also curious about others’ experiences with TXP power settings, particularly with devices like the nRF7002. I’ve heard some users wondering if they can max out the TXP for optimal communication. From what I gather, it’s generally safe to use higher TXP values, but it’s always a good idea to test in your specific environment to ensure stability and reliability.
If anyone has tips or best practices for Modbus integration or TXP settings, I’d love to hear them! It’s amazing how a community like this can help troubleshoot and optimize setups. Let’s keep the conversation going!
Cheers,
