Hey everyone, I wanted to share my recent experience optimizing my home automation setup. I’ve been using smart lighting for a while now, but recently I ran into an interesting challenge with two automations clashing. Let me walk you through how I tackled it and hopefully, this can help someone else out there!
So, here’s the setup: I have an automation that turns off the bedroom light after 4 minutes of being on to prevent it from staying on all day. On the flip side, I also have a wake-up routine that gently fades the bedroom light up over 15 minutes. The problem arose when these two automations would interfere with each other, leading to unexpected behavior.
Initially, I tried using the ‘current’ state of the automations to determine if one should pause the other. However, this approach didn’t work as smoothly as I hoped. After some research and experimentation, I discovered that utilizing the ‘active’ state of the automations provided a more reliable solution. By checking if the wake-up routine was actively running, I could prevent the light timeout automation from triggering during that period.
Here’s a quick breakdown of what I did:
- I set up a condition in the timeout automation to check if the wake-up automation was active.
- If the wake-up automation was running, the timeout automation would hold off until it completed.
- This ensured a seamless transition between the two routines without any conflicts.
It’s been running smoothly for a few weeks now, and I’m really happy with how it turned out! This experience taught me the importance of thoroughly understanding how different automations interact and the value of testing various logic conditions before settling on a solution.
If anyone else has encountered similar challenges or has tips on optimizing automation logic, I’d love to hear your thoughts! Let’s keep improving our smart home setups together. ![]()
