I’ve been working with the ION7650 meter and its high-speed reading module, and I must say, it’s been a fascinating journey. The meter itself is a marvel of precision, delivering readings at intervals as short as 5 milliseconds. However, I’ve encountered an intriguing limitation—ION Setup only allows me to extract 3000 data points, even though theoretically, I should be able to gather up to 48,000 readings in just four minutes. This has piqued my curiosity and led me on a quest to uncover the reasons behind this constraint.
Initially, I suspected it might be a storage issue. After all, 48,000 data points is a substantial amount. But upon closer inspection, I realized that storage wasn’t the bottleneck. I performed a master reset on the equipment and adjusted the storage settings within ION Setup, allocating more space to the ‘Hist mean log’ while reducing the capacity reserved for waveforms. Despite these changes, the limitation remained.
This led me to hypothesize that the issue might not be with the meter itself but rather with how ION Setup handles and displays the data. It’s possible that the software has a predefined limit on the number of data points it can process or display at once. To test this theory, I experimented with different reading intervals—5ms, 10ms, 15ms, and 20ms. In each case, ION Setup consistently capped the displayed data at 3000 points, regardless of the interval.
While I haven’t found a definitive solution yet, I’m sharing my findings in the hope that others might have encountered similar issues or have insights to offer. If anyone has successfully increased the data extraction limit in ION Setup or has alternative methods for handling large datasets, I’d be delighted to hear about your experiences. Let’s continue to explore and optimize our systems together!
