Optimizing Fortrezz Leak Sensor Alerts on UI5
I recently noticed that my Fortrezz leak sensors display temperature on the Vera UI5 interface, which is great for monitoring. However, I found it cumbersome to check the alarm status, as it required digging into advanced tabs. After some research and experimentation, I discovered a way to streamline the process by customizing the UI5 settings. By adjusting the device drivers and utilizing the built-in automation features, I was able to create a more intuitive interface that shows the alarm status directly. This tweak has significantly improved my experience, making it easier to monitor and respond to potential issues. It’s amazing how a small adjustment can make such a big difference! I’d like to thank the community for the wealth of resources and support that helped me achieve this. Happy tinkering! :hammer_and_wrench::droplet:
