Hello openHAB enthusiasts!
I’ve been diving into optimizing my gas station price tracking setup, and I wanted to share my journey and some tips that might help others facing similar challenges. ![]()
My Setup
I’m using the Tankerkoenig binding to pull gas prices from six nearby stations. The goal is to have the prices sorted and displayed in real-time. However, I noticed that when multiple stations update their prices simultaneously, my rule gets triggered multiple times, leading to redundant sorting processes. ![]()
The Challenge
The initial rule worked but wasn’t optimized. Every price change triggered a sort, which was inefficient, especially when all six stations updated at once. I wanted to streamline this process to avoid unnecessary repetitions. ![]()
My Solution
After some research and experimentation, I decided to implement a delay mechanism. Here’s how I approached it:
- Latching Logic: I introduced latching to prevent the rule from being triggered multiple times within a short period.
- Timer Delay: I set up a timer that delays the sorting process by 5 minutes after the first trigger. This ensures that only the most recent data is processed, eliminating redundant sorting.
- Efficient Sorting: The rule now sorts the prices once after the delay, providing a clean and up-to-date display.
The Rule in Action
Here’s a simplified version of the rule I’m using:
markdown
rule “Optimized Gas Station Prices”
when
Member of gGasStationPrices changed
then
val String ruleIdentifier = ruleIdentification + “OptimizedGasStationPrices”
try {
gasLatch.lock()
logInfo(ruleIdentifier, “Rule triggered by {}.”, triggeringItem.name.toString)
// Implement delay logic
if (!delayTimer.running) {
delayTimer.start(5 minutes)
logInfo(ruleIdentifier, "Sorting delayed by 5 minutes.")
// Sorting logic after delay
if (delayTimer.elapsed) {
var counter = 1
for (gasPrice : gGasStationPrices.members.sortBy[ state as DecimalType ]) {
// Update display logic here
counter++
} catch (Exception e) {
logError(ruleIdentifier, "Error in processing gas station prices: " + e.toString)
} finally {
gasLatch.unlock()
end
Tips for Others
- Latching and Delays: These techniques can be incredibly useful for preventing redundant processing in rules triggered by multiple sources.
- Testing: Always test your rules thoroughly to ensure they behave as expected, especially with delays involved.
- Logging: Use detailed logging to track the rule’s behavior and identify any issues early on.
Community Feedback
I’d love to hear how others are handling similar scenarios! Are there alternative approaches or optimizations you’ve discovered? Let’s share our experiences and continue improving our openHAB setups together! ![]()
Happy automating! ![]()
