I recently stumbled upon a fantastic tool that has really enhanced my Home Assistant setup, and I wanted to share my experience in case it helps others. The Google Maps Styling Wizard has been a game-changer for me, especially when it comes to customizing the look of my Lovelace UI. I’ve always been a bit particular about the aesthetics of my smart home dashboard, so being able to match my Google Maps cards with my light and dark themes has been a huge win.
Here’s a quick rundown of how I got it set up:
Getting Started: I followed the official Home Assistant documentation to configure the
cameracomponent and obtain my Google Maps API Key. This was straightforward, though I had to ensure my API Key was correctly formatted. -
Styling Wizard Magic: Navigating to the Google Maps Styling Wizard was the next step. I chose a base theme and tweaked the settings to align perfectly with my Lovelace UI. It’s amazing how much control you have over the map’s appearance—colors, markers, even the level of detail.
URL Configuration: After finalizing the style, I copied the generated URL and modified it to include my device trackers. This involved replacing placeholder text with actual device tracker data, which required a bit of trial and error, but the results were worth it.
Testing and Tweaks: I tested the integration thoroughly, adjusting the URL parameters as needed. Ensuring that the map centered on all GPS device trackers was a priority, and I found that omitting the
¢er=string achieved this seamlessly. -
Final Touches: I made sure to handle any device trackers that started with numbers by enclosing them in square brackets. This small detail was crucial for maintaining consistency across all my devices.
The end result has been nothing short of impressive. My Google Maps cards now look cohesive with the rest of my UI, and I can easily monitor my device trackers without any visual distractions. If you’re looking to elevate your Home Assistant setup, I highly recommend exploring the Google Maps Styling Wizard—it’s a feature that truly enhances the user experience.
If anyone has tips or tricks for further customization, I’d love to hear them! Let’s continue to push the boundaries of what’s possible with Home Assistant.
