I’ve been diving into optimizing my Home Assistant setup lately, and I wanted to share some insights and ask for advice from the community. First off, log management has been on my mind. I noticed that my Home Assistant logs were ballooning, taking up over 115 GB of space! After some digging, I realized it was due to debug logging that I had forgotten to turn off. I’ve since removed the debug settings, but I’m still unsure about the best way to clean up these logs without risking data loss. Is it safe to manually delete the log files, or should I look into automated log rotation solutions? I’d love to hear your strategies for keeping log sizes in check, especially if you have tips for preventing them from spiraling out of control in the first place.
On another note, I’ve been experimenting with media playback integration. I’ve got a bunch of sound clips stored locally, and I’m trying to set up a system where pressing a button plays a random clip from the directory. While I can play individual files without issues, figuring out how to shuffle through the entire folder has been a bit of a puzzle. I’ve tinkered with the YAML configuration, but I’m not quite there yet. Does anyone have a clever workaround or a recommended approach for setting this up? I’m particularly interested in automating the process so that each button press cycles through the clips seamlessly.
Lastly, I’d love to hear about your experiences with integrating different media players and log management practices. Have you encountered similar challenges, and how did you overcome them? Your insights could be invaluable as I continue to refine my setup. Thanks in advance for your help and tips!
