After recently expanding my Home Assistant setup, I noticed a significant slowdown in performance. Pages were taking 15+ seconds to load, which was frustrating. My system setup includes a Dell OptiPlex 900 with 20GB RAM, Fedora 31, and Home Assistant running on Oracle VirtualBox. Despite healthy CPU and RAM usage, the slowdown persisted.
I decided to dive into optimizing my system. Here’s what I’ve learned and implemented:
Regular System Monitoring: I started using Grafana and InfluxDB to monitor resource usage more effectively. This helped me identify peak load times and resource bottlenecks.
Addon Optimization: I reviewed my installed add-ons, including Grafana, HACS, Node-RED, and VSC. Unnecessary add-ons were removed or optimized to reduce their impact on system resources.
Dynamic HDD Management: My Home Assistant instance was running on a dynamically allocated 30GB HDD, which had grown to 16GB. I increased the allocated space to 50GB to provide more breathing room for logs and data.
Integration of ApexCharts: To improve visualizations without overloading the system, I implemented ApexCharts with a reduced data refresh rate. This helped balance performance and user experience.
Community Resources: I found the Home Assistant community forums invaluable. Exploring threads related to system optimization and resource management provided practical insights and solutions.
Backup and Maintenance: Regular backups and system maintenance became part of my routine. This ensures that any issues can be addressed before they escalate.
The results have been promising. Page load times have significantly improved, and the system feels more responsive. I’m now looking into further optimizations, such as upgrading the virtual machine’s resources and exploring more efficient data handling methods.
If you’re facing similar performance issues, I recommend starting with basic system health checks, reviewing add-on usage, and optimizing resource allocation. The community’s wealth of knowledge and shared experiences is a fantastic starting point.
Happy optimizing! ![]()
