Optimizing Home Automation: Automatically Control Windows with Lights
I recently decided to optimize my home automation setup to make my bathroom more energy-efficient and convenient. My goal was to automate the opening and closing of my automatic bathroom window based on the state of my bathroom lights. Here’s how I achieved it and the lessons I learned along the way!
The Challenge
I wanted the window to open when the lights turned on and close after 15 minutes, ensuring proper ventilation. Conversely, if the lights were turned off, I wanted the window to close immediately, regardless of any ongoing automation. Initially, I set up two separate automations: one to open the window when the light was on and another to close it when the light was off. However, I encountered an issue where both automations would sometimes run simultaneously, causing unexpected behavior.
The Solution
After some research and experimentation, I realized that using a single automation with conditional logic would be more effective. I utilized the mode: single setting to ensure that only the most recent trigger would execute, preventing conflicts between the two actions. Here’s a simplified version of my automation setup:
yaml
automation:
  • alias: Bathroom Window Automation
    trigger:
    • platform: state
      entity_id: light.bathroom_light
      to: ‘on’
    • platform: state
      to: ‘off’
      condition: null
      action:
    • service: cover.open_cover
      entity_id: cover.bathroom_window
      data:
      delay: 15 minutes
    • service: cover.close_cover
      mode: single
This setup ensures that when the light is turned on, the window opens and closes after 15 minutes. If the light is turned off before the 15 minutes are up, the window closes immediately.
Key Takeaways
  1. Single Mode Automation: Using mode: single was crucial in preventing conflicting automation triggers. It ensures that only the most recent trigger takes precedence.
  2. Timing and Logic: Properly timing the window closure and ensuring immediate response when the light is turned off was essential for user satisfaction.
  3. Testing and Iteration: I tested the automation extensively, adjusting the timing and logic until it met my needs perfectly.
Why This Matters
This automation not only enhances convenience but also contributes to energy efficiency. By ensuring proper ventilation when needed and closing the window promptly when not, it helps maintain a comfortable environment while saving energy.
If you’re looking to implement similar automation in your home, I recommend starting with a clear understanding of your needs and testing each component thoroughly before integrating them. Happy automating! :rocket:
