Winter is always a challenging time for balancing comfort and energy efficiency. I’ve been experimenting with my boiler settings using OpenTherm mode with Tado, and it’s been fascinating to see how much I can fine-tune the system. Here’s what I’ve learned and how it’s benefiting my home! For starters, my boiler is set to a maximum temperature of 55°C, which Tado adjusts based on outdoor weather conditions. This has been working smoothly, but I noticed something that caught my attention. The boiler pump runs quite frequently, circulating water at around 20–25°C. While this is ideal for underfloor heating, it seems inefficient for my radiators. Why does this matter? Well, if the water is circulating at such a low temperature, the radiators aren’t heating up as effectively as they could. This means the pump is running more than necessary, consuming energy and reducing its lifespan over time. My solution? I’ve been exploring the idea of setting a minimum temperature threshold, say 30°C, so the boiler only starts heating when needed. This would reduce the pump’s runtime during the day, save energy, and protect the system from unnecessary wear and tear. After some research, I found that this approach is quite common in energy-efficient systems. It’s all about finding that sweet spot where comfort meets efficiency. I’m currently monitoring the system closely to see how this adjustment impacts both comfort and energy usage. Here’s a tip for others: If you’re using a smart thermostat like Tado, take a look at your heating activity reports. They can give you insights into how your system is performing and where adjustments might be needed. For instance, my report shows between 21 and 24 hours of daily operation, which I believe could be reduced with the right settings. Another thing I’ve been considering is the integration of smart thermostats for individual rooms. This way, I can have more control over each space and avoid overheating areas that don’t need as much warmth. It’s all about layering solutions to create a system that works seamlessly for your lifestyle. If anyone has experience with setting minimum temperatures or optimizing boiler performance, I’d love to hear your insights! Let’s share tips and tricks to help each other create more efficient and comfortable homes. ![]()
