I’ve been running Home Assistant for a while now, and one thing I’ve noticed is how InfluxDB can sometimes consume a lot of memory, especially after a few days of continuous use. I set my retention policy to 90 days, but even with that, I started seeing memory issues. After some research, I found a great way to optimize InfluxDB by implementing retention policies and continuous queries, which significantly reduces memory usage without losing important data. Here’s how I did it:
Retention Policies: I created multiple retention policies to store data at different resolutions. For example, keeping high-resolution data for the first 24 hours and lower resolutions for longer periods. This ensures that older data doesn’t bloat the database.
Continuous Queries: These automatically downsample older data, reducing the amount of data stored over time. I set up queries to aggregate data every 10 minutes, 30 minutes, and so on, which helps maintain performance.
Script Adjustments: I made sure to add semicolons at the end of each command in my scripts, which was a small but crucial fix to ensure everything runs smoothly.
By implementing these changes, I’ve noticed a significant improvement in InfluxDB’s performance. It’s now more stable, and I don’t have to worry about running out of memory as often. If you’re experiencing similar issues, I highly recommend giving this method a try! ![]()
