Optimizing Lighting Automation with Motion Sensors
I’ve been diving into the world of smart lighting automation, and I’m excited to share my experience and a tip that might help others looking to streamline their setups.
In my office, I have lights controlled by a motion sensor, and I wanted to create a seamless experience. Here’s what I aimed to achieve:
  1. Lights On with Motion: If the lights are off and motion is detected, they should turn on at full brightness (100%).
  2. Leave Them Be: If the lights are already on, I don’t want them to reset to 100% brightness if motion is detected again—perfect for when I’ve dimmed them for reading or focus.
  3. Lights Off After Inactivity: If no motion is detected for 15 minutes, the lights should turn off automatically.
Initially, I set this up using two rules, but I felt there should be a way to do it with just one. After some experimentation, I found that using a single rule with conditional statements worked perfectly. This not only simplified my setup but also made it more efficient.
Tip for Others: If you’re using motion sensors with dimmable lights, consider setting up your rules to check the current state of the lights before making adjustments. This can prevent unnecessary brightness changes and ensure a smoother user experience.
I’m still learning the ropes of smart home automation, but it’s been a rewarding journey. I’m curious to hear how others have tackled similar setups or if there are even more efficient methods out there!
