I recently discovered a fantastic feature of the Neo Coolcam Plugs, often referred to as ‘Pimpen.’ These smart plugs come with an adjustable current limit setting, which I initially overlooked. After some experimentation, I found that this feature can be incredibly useful for managing power consumption and ensuring safety for heavy appliances.
My Experience
I purchased these plugs primarily for controlling LED lighting and small electronics. However, during a routine check of their settings, I stumbled upon the ‘Advanced Settings’ menu. There, I found an option to adjust the current limit from the default 13A to a maximum of 16A. This adjustment increases the maximum power capacity from 2800W to 3500W, making it suitable for larger appliances like washing machines or electric kettles.
Why This Matters
For anyone looking to expand the use of their smart plugs beyond small electronics, this feature is a game-changer. It allows homeowners to integrate heavy-duty appliances into their smart home ecosystem without compromising safety. I’ve been using this setting for a few weeks now, and it’s been reliable and efficient.
How to Adjust the Setting
Adjusting the current limit is straightforward:
- Open the Neo Coolcam app.
- Navigate to the specific plug you want to configure.
- Go to ‘Advanced Settings.’
- Locate the ‘Current Limit’ option and adjust it to your desired level.
Safety First
While this feature is incredibly useful, I recommend exercising caution. Always ensure that the adjusted current limit does not exceed the safe capacity of your appliances or circuits. It’s also a good idea to monitor the plug’s performance initially to ensure everything runs smoothly.
Conclusion
The Neo Coolcam Plugs are versatile devices that can handle a wide range of applications. By taking advantage of their adjustable current limit feature, users can optimize their smart home setup for both small and heavy-duty appliances. If you haven’t explored this feature yet, I highly recommend giving it a try—it might just unlock new possibilities for your smart home!
Let me know if you’ve tried this or have any other tips for optimizing smart plugs!
